Run Time: 0.000767
Run Time: 0.000206
WHERE (`xf_thread`.`thread_id` = '37618')
Run Time: 0.000753
WHERE (`xf_post`.`thread_id` = 37618) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002726
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (580857, 580858, 580860, 580950, 580968, 580973, 581061, 581163))
Run Time: 0.002219
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 13 | Using index condition; Using filesort |
Params: 37618
Run Time: 0.000117
Params: 0,
Run Time: 0.000205
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=37618, 1716253740, , 0,
Run Time: 0.000148
WHERE (`xf_session_activity`.`user_id` = 19808) AND (`xf_session_activity`.`unique_key` = '19808')
Run Time: 0.000185
WHERE (`xf_thread_reply_ban`.`thread_id` = 37618) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000223
Run Time: 0.000204
bytes_sent | 12423 |
bytes_received | 292394 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 219634 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 901 |
proto_binary_fetched_short | 198 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 638 |
proto_binary_fetched_decimal | 37 |
proto_binary_fetched_json | 512 |
proto_binary_fetched_blob | 195 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 217943 |
