Run Time: 0.000506
Run Time: 0.000230
WHERE (`xf_thread`.`thread_id` = '34655')
Run Time: 0.000566
WHERE (`xf_post`.`thread_id` = 34655) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004120
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (520837, 520928))
Run Time: 0.001208
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
Params: 34655
Run Time: 0.000104
Params: 0,
Run Time: 0.000143
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=34655, 1714321934, , 0,
Run Time: 0.000123
WHERE (`xf_session_activity`.`user_id` = 16372) AND (`xf_session_activity`.`unique_key` = '16372')
Run Time: 0.000200
WHERE (`xf_thread_reply_ban`.`thread_id` = 34655) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000235
Run Time: 0.000180
bytes_sent | 12320 |
bytes_received | 363243 |
packets_sent | 124 |
packets_received | 1095 |
protocol_overhead_in | 4380 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 290442 |
packets_sent_command | 61 |
packets_received_change_user | 115 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 97 |
rows_buffered_from_client_ps | 97 |
rows_skipped_ps | 97 |
proto_binary_fetched_bit | 914 |
proto_binary_fetched_short | 387 |
proto_binary_fetched_bigint | 1094 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 721 |
proto_binary_fetched_blob | 354 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 288097 |
