Run Time: 0.000714
Run Time: 0.000224
WHERE (`xf_thread`.`thread_id` = '42033')
Run Time: 0.001188
WHERE (`xf_post`.`thread_id` = 42033) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001957
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 7 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (674940))
Run Time: 0.001043
Params: 42033
Run Time: 0.000096
Params: 0, vȈ
Run Time: 0.000171
Params: vȈ, XF\Pub\Controller\Thread, Index, valid, thread_id=42033, 1714202382, , 0, vȈ
Run Time: 0.000158
WHERE (`xf_session_activity`.`user_id` = 45125) AND (`xf_session_activity`.`unique_key` = '45125')
Run Time: 0.000204
WHERE (`xf_thread_reply_ban`.`thread_id` = 42033) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000228
Run Time: 0.000215
bytes_sent | 12304 |
bytes_received | 280738 |
packets_sent | 124 |
packets_received | 1072 |
protocol_overhead_in | 4288 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 207937 |
packets_sent_command | 61 |
packets_received_change_user | 92 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 74 |
rows_buffered_from_client_ps | 74 |
rows_skipped_ps | 74 |
proto_binary_fetched_bit | 161 |
proto_binary_fetched_short | 141 |
proto_binary_fetched_int24 | 56 |
proto_binary_fetched_bigint | 383 |
proto_binary_fetched_json | 413 |
proto_binary_fetched_blob | 158 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 206622 |
