Run Time: 0.000691
Run Time: 0.000202
WHERE (`xf_thread`.`thread_id` = '11774')
Run Time: 0.001189
WHERE (`xf_post`.`thread_id` = 11774) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004736
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (123940, 124006, 124155, 124314, 124326, 124351, 124354, 124819, 125020, 125388, 125516))
Run Time: 0.002292
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 17 | Using index condition; Using filesort |
Params: 11774
Run Time: 0.000105
Params: 0,
Run Time: 0.000162
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=11774, 1717068033, , 0,
Run Time: 0.000152
WHERE (`xf_session_activity`.`user_id` = 12333) AND (`xf_session_activity`.`unique_key` = '12333')
Run Time: 0.000192
WHERE (`xf_thread_reply_ban`.`thread_id` = 11774) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000212
Run Time: 0.000207
bytes_sent | 12464 |
bytes_received | 361133 |
packets_sent | 124 |
packets_received | 1101 |
protocol_overhead_in | 4404 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 288332 |
packets_sent_command | 61 |
packets_received_change_user | 121 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 103 |
rows_buffered_from_client_ps | 103 |
rows_skipped_ps | 103 |
proto_binary_fetched_bit | 1271 |
proto_binary_fetched_short | 393 |
proto_binary_fetched_bigint | 1178 |
proto_binary_fetched_decimal | 41 |
proto_binary_fetched_json | 751 |
proto_binary_fetched_blob | 363 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 285846 |
