Run Time: 0.000377
Run Time: 0.000181
WHERE (`xf_thread`.`thread_id` = '22832')
Run Time: 0.000893
WHERE (`xf_post`.`thread_id` = 22832) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004394
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (307786))
Run Time: 0.001532
SIMPLE | xf_attachment | ref | content_type_id_date,content_type | content_type_id_date | 31 | const,const | 13 | Using index condition; Using where |
Params: 22832
Run Time: 0.000126
Params: 0,
Run Time: 0.000121
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=22832, 1714242076, , 0,
Run Time: 0.000143
WHERE (`xf_session_activity`.`user_id` = 25249) AND (`xf_session_activity`.`unique_key` = '25249')
Run Time: 0.000158
WHERE (`xf_thread_reply_ban`.`thread_id` = 22832) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000189
Run Time: 0.000206
bytes_sent | 12304 |
bytes_received | 358970 |
packets_sent | 124 |
packets_received | 1097 |
protocol_overhead_in | 4388 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 286169 |
packets_sent_command | 61 |
packets_received_change_user | 117 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 99 |
rows_buffered_from_client_ps | 99 |
rows_skipped_ps | 99 |
proto_binary_fetched_bit | 1038 |
proto_binary_fetched_short | 386 |
proto_binary_fetched_bigint | 1123 |
proto_binary_fetched_decimal | 37 |
proto_binary_fetched_json | 732 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 283812 |
