Run Time: 0.000694
Run Time: 0.000223
WHERE (`xf_thread`.`thread_id` = '7902')
Run Time: 0.000886
WHERE (`xf_post`.`thread_id` = 7902) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002625
Params: 7902
Run Time: 0.000099
Params: 0, ӆ
Run Time: 0.000154
Params: ӆ, XF\Pub\Controller\Thread, Index, valid, thread_id=7902, 1714955662, , 0, ӆ
Run Time: 0.000151
WHERE (`xf_session_activity`.`user_id` = 9298) AND (`xf_session_activity`.`unique_key` = '9298')
Run Time: 0.000182
WHERE (`xf_thread_reply_ban`.`thread_id` = 7902) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000188
Run Time: 0.000177
bytes_sent | 9828 |
bytes_received | 249941 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 195162 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 80 |
proto_binary_fetched_short | 104 |
proto_binary_fetched_bigint | 280 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 194075 |
