Run Time: 0.000580
Run Time: 0.000191
WHERE (`xf_thread`.`thread_id` = '14745')
Run Time: 0.000990
WHERE (`xf_post`.`thread_id` = 14745) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003821
Params: 14745
Run Time: 0.000086
Params: 0, :'
Run Time: 0.000180
Params: :', XF\Pub\Controller\Thread, Index, valid, thread_id=14745, 1714320993, , 0, :'
Run Time: 0.000132
WHERE (`xf_session_activity`.`user_id` = 8439) AND (`xf_session_activity`.`unique_key` = '8439')
Run Time: 0.000238
WHERE (`xf_thread_reply_ban`.`thread_id` = 14745) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000242
Run Time: 0.000218
bytes_sent | 9836 |
bytes_received | 308818 |
packets_sent | 112 |
packets_received | 880 |
protocol_overhead_in | 3520 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 254039 |
packets_sent_command | 55 |
packets_received_change_user | 92 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 76 |
rows_buffered_from_client_ps | 76 |
rows_skipped_ps | 76 |
proto_binary_fetched_bit | 198 |
proto_binary_fetched_short | 276 |
proto_binary_fetched_bigint | 720 |
proto_binary_fetched_json | 523 |
proto_binary_fetched_blob | 277 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 252346 |
