Focusing problem
Bengan
Welcome to the forum
It's very difficult to help with this little information.
How is the AF set up? Back button or shutter release half press? Which lens is it and is it set to AF. Have you tried more than one lens. Have you tried cleaning the lens and body contacts?
Please tell us some more.
harishpr
AF set up in shutter release half press.
when i do Shutter release half press its not focusing
i have used with nikkor AF-S 24-120 and 70-300 lens
i never tried of cleaning lens,please let me know how to clean lens.
Is it focusing or just not focusing on the subject?
What focusing mode are you using? Depending on subject, some modes are better than others.
Are you absolutely certain that the focus switch on the body hasn't been accidentally moved?
Have you tried the back button to see if it works? This could help you pin-point the culprit setting that's preventing the half-pressed focus acquisition.
More questions, but it's the only way to diagnose the problem and find the right solution.
Bengan
Assuming you have the lenses set to AF and that neither shutter release nor AF button works. Have you tried AF in Live View? If live view works there is not any problem with the contacts.
Did the problem start suddenly or did you notice it now and then to begin with?
Cleaning lens and body contacts I'd start with just a microfiber cloth and if that doesn't do it trying small amounts of something like DeoxIT on the cloth.
Have you tried toggling the AF/M switches back and forth? Usually the lens has one as do many bodies. Be sure to do both if possible.
harishpr
It is not focusing on the subject
I am using AF mode and coming to manual mode its working.
basically the focus point is not working..its not focusing on the subject as we half click the shutter it focus on the subject, in my camera its not working.
please help me out.
harishpr
Actually its set to AF and I have tried in live view but still its not working.
Actually the problem started nearly a week ago.
harishpr
i have tried switching AF/M back and forth and i tried on the lens too still the same problem..
If i do any factory reset does this problem goes?
If it does how to do factory reset... please let me know
harishpr
Thank you guys finally I got the solution.... You guys were truely helpful...
Thank you so much guys ill be in touch.
Thank you
Thank you
You know that if you would share the solution with us you could in turn help someone else.
I think it would be very kind of you to tell us what the solution was.
Bikerbrent
Yes, we all like to know what the solution was!
harishpr
Actually it was in Auto Focusing points were auto and the Auto Focusing was not with the shutter release.
This was the problem and i got the solution.
