Run Time: 0.000801
Run Time: 0.000223
WHERE (`xf_thread`.`thread_id` = '29540')
Run Time: 0.000792
WHERE (`xf_post`.`thread_id` = 29540) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003001
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (431481))
Run Time: 0.001521
Params: 29540
Run Time: 0.000108
Params: 0,
Run Time: 0.000170
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=29540, 1714766923, , 0,
Run Time: 0.000131
WHERE (`xf_session_activity`.`user_id` = 37908) AND (`xf_session_activity`.`unique_key` = '37908')
Run Time: 0.000193
WHERE (`xf_thread_reply_ban`.`thread_id` = 29540) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000224
Run Time: 0.000211
bytes_sent | 12311 |
bytes_received | 324827 |
packets_sent | 124 |
packets_received | 1080 |
protocol_overhead_in | 4320 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 252067 |
packets_sent_command | 61 |
packets_received_change_user | 100 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 82 |
rows_buffered_from_client_ps | 82 |
rows_skipped_ps | 82 |
proto_binary_fetched_bit | 257 |
proto_binary_fetched_short | 276 |
proto_binary_fetched_bigint | 736 |
proto_binary_fetched_json | 573 |
proto_binary_fetched_blob | 278 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 250270 |
