Run Time: 0.000711
Run Time: 0.000204
WHERE (`xf_thread`.`thread_id` = '16405')
Run Time: 0.001166
WHERE (`xf_post`.`thread_id` = 16405) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002646
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 3 | Using where; Using filesort |
Params: 16405
Run Time: 0.000100
Params: 0, ud
Run Time: 0.000172
Params: ud, XF\Pub\Controller\Thread, Index, valid, thread_id=16405, 1717323739, , 0, ud
Run Time: 0.000153
WHERE (`xf_session_activity`.`user_id` = 16502) AND (`xf_session_activity`.`unique_key` = '16502')
Run Time: 0.000176
WHERE (`xf_thread_reply_ban`.`thread_id` = 16405) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000231
bytes_sent | 9840 |
bytes_received | 238891 |
packets_sent | 112 |
packets_received | 868 |
protocol_overhead_in | 3472 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 184112 |
packets_sent_command | 55 |
packets_received_change_user | 80 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 64 |
rows_buffered_from_client_ps | 64 |
rows_skipped_ps | 64 |
proto_binary_fetched_bit | 56 |
proto_binary_fetched_short | 70 |
proto_binary_fetched_int24 | 28 |
proto_binary_fetched_bigint | 192 |
proto_binary_fetched_json | 283 |
proto_binary_fetched_blob | 97 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 183149 |
