Run Time: 0.000725
Run Time: 0.000214
WHERE (`xf_thread`.`thread_id` = '32525')
Run Time: 0.001001
WHERE (`xf_post`.`thread_id` = 32525) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002382
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 9 | Using where; Using filesort |
Params: 32525
Run Time: 0.000090
Params: 0, ;d*
Run Time: 0.000191
Params: ;d*, XF\Pub\Controller\Thread, Index, valid, thread_id=32525, 1714323713, , 0, ;d*
Run Time: 0.000163
WHERE (`xf_session_activity`.`user_id` = 19257) AND (`xf_session_activity`.`unique_key` = '19257')
Run Time: 0.000183
WHERE (`xf_thread_reply_ban`.`thread_id` = 32525) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000199
Run Time: 0.000233
bytes_sent | 9840 |
bytes_received | 269405 |
packets_sent | 112 |
packets_received | 874 |
protocol_overhead_in | 3496 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 214626 |
packets_sent_command | 55 |
packets_received_change_user | 86 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 70 |
rows_buffered_from_client_ps | 70 |
rows_skipped_ps | 70 |
proto_binary_fetched_bit | 128 |
proto_binary_fetched_short | 172 |
proto_binary_fetched_int24 | 70 |
proto_binary_fetched_bigint | 456 |
proto_binary_fetched_json | 403 |
proto_binary_fetched_blob | 187 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 213307 |
