Run Time: 0.000747
Run Time: 0.000212
WHERE (`xf_thread`.`thread_id` = '41176')
Run Time: 0.000799
WHERE (`xf_post`.`thread_id` = 41176) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003928
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (657463, 657608, 657631, 657638, 658109, 658111, 658238, 658262, 658343, 658382, 658561, 658562, 658563, 658592, 658593))
Run Time: 0.003306
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 15 | Using index condition; Using filesort |
Params: 41176
Run Time: 0.000099
Params: 0,
Run Time: 0.000202
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=41176, 1714303990, , 0,
Run Time: 0.000171
WHERE (`xf_session_activity`.`user_id` = 27017) AND (`xf_session_activity`.`unique_key` = '27017')
Run Time: 0.000196
WHERE (`xf_thread_reply_ban`.`thread_id` = 41176) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000218
Run Time: 0.000256
bytes_sent | 12528 |
bytes_received | 353740 |
packets_sent | 124 |
packets_received | 1099 |
protocol_overhead_in | 4396 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 280939 |
packets_sent_command | 61 |
packets_received_change_user | 119 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 101 |
rows_buffered_from_client_ps | 101 |
rows_skipped_ps | 101 |
proto_binary_fetched_bit | 1115 |
proto_binary_fetched_short | 397 |
proto_binary_fetched_bigint | 1160 |
proto_binary_fetched_decimal | 39 |
proto_binary_fetched_json | 755 |
proto_binary_fetched_blob | 367 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 278531 |
