Run Time: 0.000858
Run Time: 0.000214
WHERE (`xf_thread`.`thread_id` = '18463')
Run Time: 0.000973
WHERE (`xf_post`.`thread_id` = 18463) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003109
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (226334, 226340, 226346, 226349, 226367, 226371))
Run Time: 0.000869
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 7 | Using index condition; Using filesort |
Params: 18463
Run Time: 0.000105
Params: 0, ;ړ
Run Time: 0.000154
Params: ;ړ, XF\Pub\Controller\Thread, Index, valid, thread_id=18463, 1714207665, , 0, ;ړ
Run Time: 0.000152
WHERE (`xf_session_activity`.`user_id` = 9753) AND (`xf_session_activity`.`unique_key` = '9753')
Run Time: 0.000185
WHERE (`xf_thread_reply_ban`.`thread_id` = 18463) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000233
Run Time: 0.000208
bytes_sent | 12380 |
bytes_received | 353879 |
packets_sent | 124 |
packets_received | 1091 |
protocol_overhead_in | 4364 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 281078 |
packets_sent_command | 61 |
packets_received_change_user | 111 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 93 |
rows_buffered_from_client_ps | 93 |
rows_skipped_ps | 93 |
proto_binary_fetched_bit | 676 |
proto_binary_fetched_short | 373 |
proto_binary_fetched_bigint | 1038 |
proto_binary_fetched_decimal | 31 |
proto_binary_fetched_json | 701 |
proto_binary_fetched_blob | 358 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 278851 |
