Run Time: 0.000765
Run Time: 0.000224
WHERE (`xf_thread`.`thread_id` = '27358')
Run Time: 0.000754
WHERE (`xf_post`.`thread_id` = 27358) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003154
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (388205, 388310, 388334, 388358))
Run Time: 0.001311
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 25 | Using index condition; Using filesort |
Params: 27358
Run Time: 0.000087
Params: 0,
Run Time: 0.000127
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=27358, 1715148123, , 0,
Run Time: 0.000147
WHERE (`xf_session_activity`.`user_id` = 24285) AND (`xf_session_activity`.`unique_key` = '24285')
Run Time: 0.000160
WHERE (`xf_thread_reply_ban`.`thread_id` = 27358) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000196
Run Time: 0.000191
bytes_sent | 12352 |
bytes_received | 367232 |
packets_sent | 124 |
packets_received | 1109 |
protocol_overhead_in | 4436 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 294431 |
packets_sent_command | 61 |
packets_received_change_user | 129 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 111 |
rows_buffered_from_client_ps | 111 |
rows_skipped_ps | 111 |
proto_binary_fetched_bit | 1758 |
proto_binary_fetched_short | 409 |
proto_binary_fetched_bigint | 1290 |
proto_binary_fetched_decimal | 49 |
proto_binary_fetched_json | 791 |
proto_binary_fetched_blob | 356 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 291820 |
