Run Time: 0.000741
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '22525')
Run Time: 0.000758
WHERE (`xf_post`.`thread_id` = 22525) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003044
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (302082, 302084, 302086, 302088, 302089, 302091, 302092, 302093, 302094, 302096, 302098, 302100, 302101, 302102, 302104))
Run Time: 0.002026
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 32 | Using index condition; Using filesort |
Params: 22525
Run Time: 0.000081
Params: 0, t q
Run Time: 0.000156
Params: t q, XF\Pub\Controller\Thread, Index, valid, thread_id=22525, 1714225663, , 0, t q
Run Time: 0.000150
WHERE (`xf_session_activity`.`user_id` = 21543) AND (`xf_session_activity`.`unique_key` = '21543')
Run Time: 0.000198
WHERE (`xf_thread_reply_ban`.`thread_id` = 22525) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000213
bytes_sent | 12528 |
bytes_received | 363629 |
packets_sent | 124 |
packets_received | 1116 |
protocol_overhead_in | 4464 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 290828 |
packets_sent_command | 61 |
packets_received_change_user | 136 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 118 |
rows_buffered_from_client_ps | 118 |
rows_skipped_ps | 118 |
proto_binary_fetched_bit | 2167 |
proto_binary_fetched_short | 423 |
proto_binary_fetched_bigint | 1388 |
proto_binary_fetched_decimal | 56 |
proto_binary_fetched_json | 826 |
proto_binary_fetched_blob | 367 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 288055 |
