Run Time: 0.000527
Run Time: 0.000187
WHERE (`xf_thread`.`thread_id` = '26893')
Run Time: 0.000664
WHERE (`xf_post`.`thread_id` = 26893) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001348
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 6 | Using where; Using filesort |
Params: 26893
Run Time: 0.000089
Params: 0, ^
Run Time: 0.000130
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ^, XF\Pub\Controller\Thread, Index, valid, thread_id=26893, 1715297780, , 0, ^
Run Time: 0.000089
WHERE (`xf_session_activity`.`user_id` = 6277) AND (`xf_session_activity`.`unique_key` = '6277')
Run Time: 0.000197
WHERE (`xf_thread_reply_ban`.`thread_id` = 26893) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000223
bytes_sent | 9849 |
bytes_received | 259838 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 205100 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 92 |
proto_binary_fetched_short | 121 |
proto_binary_fetched_int24 | 49 |
proto_binary_fetched_bigint | 323 |
proto_binary_fetched_json | 343 |
proto_binary_fetched_blob | 142 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 203942 |
