Run Time: 0.000687
Run Time: 0.000243
WHERE (`xf_thread`.`thread_id` = '9992')
Run Time: 0.000792
WHERE (`xf_post`.`thread_id` = 9992) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004926
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (100510, 100511, 101050, 101152, 102233, 102256, 102558, 103291))
Run Time: 0.001651
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 14 | Using index condition; Using filesort |
Params: 9992
Run Time: 0.000117
Params: 0, t(/
Run Time: 0.000194
Params: t(/, XF\Pub\Controller\Thread, Index, valid, thread_id=9992, 1714247658, , 0, t(/
Run Time: 0.000154
WHERE (`xf_session_activity`.`user_id` = 12060) AND (`xf_session_activity`.`unique_key` = '12060')
Run Time: 0.000200
WHERE (`xf_thread_reply_ban`.`thread_id` = 9992) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000271
Run Time: 0.000252
bytes_sent | 12408 |
bytes_received | 355663 |
packets_sent | 124 |
packets_received | 1098 |
protocol_overhead_in | 4392 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 282862 |
packets_sent_command | 61 |
packets_received_change_user | 118 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 100 |
rows_buffered_from_client_ps | 100 |
rows_skipped_ps | 100 |
proto_binary_fetched_bit | 1092 |
proto_binary_fetched_short | 388 |
proto_binary_fetched_bigint | 1137 |
proto_binary_fetched_decimal | 38 |
proto_binary_fetched_json | 736 |
proto_binary_fetched_blob | 360 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 280494 |
