Run Time: 0.000385
Run Time: 0.000222
WHERE (`xf_thread`.`thread_id` = '19230')
Run Time: 0.000811
WHERE (`xf_post`.`thread_id` = 19230) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004101
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (239534, 239607))
Run Time: 0.001094
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 2 | Using index condition; Using filesort |
Params: 19230
Run Time: 0.000090
Params: 0, ٶ-
Run Time: 0.000180
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ٶ-, XF\Pub\Controller\Thread, Index, valid, thread_id=19230, 1714909172, , 0, ٶ-
Run Time: 0.000125
WHERE (`xf_session_activity`.`user_id` = 15356) AND (`xf_session_activity`.`unique_key` = '15356')
Run Time: 0.000197
WHERE (`xf_thread_reply_ban`.`thread_id` = 19230) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000270
Run Time: 0.000226
bytes_sent | 12327 |
bytes_received | 362003 |
packets_sent | 124 |
packets_received | 1086 |
protocol_overhead_in | 4344 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 289243 |
packets_sent_command | 61 |
packets_received_change_user | 106 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 88 |
rows_buffered_from_client_ps | 88 |
rows_skipped_ps | 88 |
proto_binary_fetched_bit | 378 |
proto_binary_fetched_short | 364 |
proto_binary_fetched_bigint | 968 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 676 |
proto_binary_fetched_blob | 355 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 287104 |
