Run Time: 0.000640
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '19804')
Run Time: 0.000995
WHERE (`xf_post`.`thread_id` = 19804) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002989
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (250919))
Run Time: 0.001102
Params: 19804
Run Time: 0.000088
Params: 0, v~
Run Time: 0.000145
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: v~, XF\Pub\Controller\Thread, Index, valid, thread_id=19804, 1715815694, , 0, v~
Run Time: 0.000102
WHERE (`xf_session_activity`.`user_id` = 13860) AND (`xf_session_activity`.`unique_key` = '13860')
Run Time: 0.000196
WHERE (`xf_thread_reply_ban`.`thread_id` = 19804) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000216
bytes_sent | 12317 |
bytes_received | 357122 |
packets_sent | 124 |
packets_received | 1084 |
protocol_overhead_in | 4336 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 284362 |
packets_sent_command | 61 |
packets_received_change_user | 104 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 86 |
rows_buffered_from_client_ps | 86 |
rows_skipped_ps | 86 |
proto_binary_fetched_bit | 320 |
proto_binary_fetched_short | 362 |
proto_binary_fetched_bigint | 953 |
proto_binary_fetched_json | 672 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 282256 |
