Run Time: 0.000610
Run Time: 0.000213
WHERE (`xf_thread`.`thread_id` = '45815')
Run Time: 0.000766
WHERE (`xf_post`.`thread_id` = 45815) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002162
Params: 45815
Run Time: 0.000083
Params: 0,
Run Time: 0.000193
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=45815, 1714668761, , 0,
Run Time: 0.000101
WHERE (`xf_thread_reply_ban`.`thread_id` = 45815) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000218
Run Time: 0.000214
bytes_sent | 9355 |
bytes_received | 250326 |
packets_sent | 100 |
packets_received | 821 |
protocol_overhead_in | 3284 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 114 |
bytes_received_prepare_response_packet | 51458 |
bytes_received_change_user_packet | 198018 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 672 |
packets_received_change_user | 79 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_fetched_from_server_ps | 65 |
rows_buffered_from_client_ps | 65 |
rows_skipped_ps | 65 |
proto_binary_fetched_bit | 51 |
proto_binary_fetched_short | 106 |
proto_binary_fetched_bigint | 286 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 335 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 196930 |
