Run Time: 0.000774
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '18474')
Run Time: 0.000893
WHERE (`xf_post`.`thread_id` = 18474) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002871
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 20 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (226448))
Run Time: 0.001088
Params: 18474
Run Time: 0.000100
Params: 0,
Run Time: 0.000130
WHERE (`xf_session_activity`.`user_id` = 18281) AND (`xf_session_activity`.`unique_key` = '18281')
Run Time: 0.000183
WHERE (`xf_thread_reply_ban`.`thread_id` = 18474) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000191
Run Time: 0.000173
bytes_sent | 11902 |
bytes_received | 351466 |
packets_sent | 118 |
packets_received | 1073 |
protocol_overhead_in | 4292 |
protocol_overhead_out | 472 |
bytes_received_rset_header_packet | 369 |
bytes_received_rset_row_packet | 123 |
bytes_received_prepare_response_packet | 71491 |
bytes_received_change_user_packet | 278985 |
packets_sent_command | 58 |
packets_received_rset_header | 41 |
packets_received_rset_row | 21 |
packets_received_prepare_response | 885 |
packets_received_change_user | 105 |
result_set_queries | 18 |
non_result_set_queries | 3 |
ps_buffered_sets | 18 |
ps_prepared_once_executed | 18 |
rows_fetched_from_server_ps | 87 |
rows_buffered_from_client_ps | 87 |
rows_skipped_ps | 87 |
proto_binary_fetched_bit | 318 |
proto_binary_fetched_short | 362 |
proto_binary_fetched_bigint | 954 |
proto_binary_fetched_json | 673 |
com_stmt_prepare | 19 |
com_stmt_execute | 19 |
com_stmt_close | 18 |
bytes_received_real_data_ps | 276889 |
