Run Time: 0.000682
Run Time: 0.000239
WHERE (`xf_thread`.`thread_id` = '42867')
Run Time: 0.000813
WHERE (`xf_post`.`thread_id` = 42867) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003925
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (693912, 695583, 695971, 696035, 696409, 696410, 696463))
Run Time: 0.001947
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 14 | Using index condition; Using filesort |
Params: 42867
Run Time: 0.000088
Params: 0,
Run Time: 0.000156
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=42867, 1714751591, , 0,
Run Time: 0.000120
WHERE (`xf_session_activity`.`user_id` = 34269) AND (`xf_session_activity`.`unique_key` = '34269')
Run Time: 0.000164
WHERE (`xf_thread_reply_ban`.`thread_id` = 42867) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000209
Run Time: 0.000195
bytes_sent | 12407 |
bytes_received | 372525 |
packets_sent | 124 |
packets_received | 1098 |
protocol_overhead_in | 4392 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 299765 |
packets_sent_command | 61 |
packets_received_change_user | 118 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 100 |
rows_buffered_from_client_ps | 100 |
rows_skipped_ps | 100 |
proto_binary_fetched_bit | 1069 |
proto_binary_fetched_short | 402 |
proto_binary_fetched_bigint | 1140 |
proto_binary_fetched_decimal | 38 |
proto_binary_fetched_json | 743 |
proto_binary_fetched_blob | 359 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 297349 |
