Run Time: 0.000715
Run Time: 0.000201
WHERE (`xf_thread`.`thread_id` = '42208')
Run Time: 0.000760
WHERE (`xf_post`.`thread_id` = 42208) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002365
Params: 42208
Run Time: 0.000089
Params: 0, 8-
Run Time: 0.000141
Params: 8-, XF\Pub\Controller\Thread, Index, valid, thread_id=42208, 1714247914, , 0, 8-
Run Time: 0.000133
WHERE (`xf_session_activity`.`user_id` = 44635) AND (`xf_session_activity`.`unique_key` = '44635')
Run Time: 0.000193
WHERE (`xf_thread_reply_ban`.`thread_id` = 42208) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000222
Run Time: 0.000215
bytes_sent | 9840 |
bytes_received | 249787 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 195008 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 79 |
proto_binary_fetched_short | 105 |
proto_binary_fetched_bigint | 280 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 193925 |
