Run Time: 0.000416
Run Time: 0.000244
WHERE (`xf_thread`.`thread_id` = '42454')
Run Time: 0.000798
WHERE (`xf_post`.`thread_id` = 42454) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002182
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (684440))
Run Time: 0.001278
Params: 42454
Run Time: 0.000097
Params: 0, vͥ
Run Time: 0.000150
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: vͥ, XF\Pub\Controller\Thread, Index, valid, thread_id=42454, 1716283167, , 0, vͥ
Run Time: 0.000118
WHERE (`xf_session_activity`.`user_id` = 14174) AND (`xf_session_activity`.`unique_key` = '14174')
Run Time: 0.000191
WHERE (`xf_thread_reply_ban`.`thread_id` = 42454) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000238
Run Time: 0.000240
bytes_sent | 12317 |
bytes_received | 303484 |
packets_sent | 124 |
packets_received | 1074 |
protocol_overhead_in | 4296 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 230724 |
packets_sent_command | 61 |
packets_received_change_user | 94 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 76 |
rows_buffered_from_client_ps | 76 |
rows_skipped_ps | 76 |
proto_binary_fetched_bit | 196 |
proto_binary_fetched_short | 192 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 515 |
proto_binary_fetched_json | 473 |
proto_binary_fetched_blob | 203 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 229214 |
