Run Time: 0.000430
Run Time: 0.000180
WHERE (`xf_thread`.`thread_id` = '18130')
Run Time: 0.000675
WHERE (`xf_post`.`thread_id` = 18130) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003451
Params: 18130
Run Time: 0.000099
Params: 0,
Run Time: 0.000142
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=18130, 1714250520, , 0,
Run Time: 0.000126
WHERE (`xf_thread_reply_ban`.`thread_id` = 18130) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000208
Run Time: 0.000213
bytes_sent | 9348 |
bytes_received | 333820 |
packets_sent | 100 |
packets_received | 836 |
protocol_overhead_in | 3344 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 155 |
bytes_received_prepare_response_packet | 51458 |
bytes_received_change_user_packet | 281471 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 672 |
packets_received_change_user | 94 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 164 |
proto_binary_fetched_short | 368 |
proto_binary_fetched_bigint | 958 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 683 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 279404 |
