Run Time: 0.000810
Run Time: 0.000245
WHERE (`xf_thread`.`thread_id` = '18816')
Run Time: 0.000820
WHERE (`xf_post`.`thread_id` = 18816) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002249
Params: 18816
Run Time: 0.000108
Params: 0, ӆ
Run Time: 0.000193
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ӆ, XF\Pub\Controller\Thread, Index, valid, thread_id=18816, 1715319734, , 0, ӆ
Run Time: 0.000131
WHERE (`xf_session_activity`.`user_id` = 6573) AND (`xf_session_activity`.`unique_key` = '6573')
Run Time: 0.000230
WHERE (`xf_thread_reply_ban`.`thread_id` = 18816) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000227
Run Time: 0.000241
bytes_sent | 9843 |
bytes_received | 250027 |
packets_sent | 112 |
packets_received | 870 |
protocol_overhead_in | 3480 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 195289 |
packets_sent_command | 55 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 80 |
proto_binary_fetched_short | 104 |
proto_binary_fetched_bigint | 280 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 194200 |
