Run Time: 0.000725
Run Time: 0.000249
WHERE (`xf_thread`.`thread_id` = '23249')
Run Time: 0.000804
WHERE (`xf_post`.`thread_id` = 23249) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003389
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
Params: 23249
Run Time: 0.000107
Params: 0,
Run Time: 0.000163
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=23249, 1714290148, , 0,
Run Time: 0.000151
WHERE (`xf_session_activity`.`user_id` = 15356) AND (`xf_session_activity`.`unique_key` = '15356')
Run Time: 0.000213
Run Time: 0.000207
bytes_sent | 9344 |
bytes_received | 339960 |
packets_sent | 100 |
packets_received | 840 |
protocol_overhead_in | 3360 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 155 |
bytes_received_prepare_response_packet | 51818 |
bytes_received_change_user_packet | 287251 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 676 |
packets_received_change_user | 94 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 254 |
proto_binary_fetched_short | 359 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 620 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 285275 |
