Run Time: 0.000695
Run Time: 0.000207
WHERE (`xf_thread`.`thread_id` = '22738')
Run Time: 0.000790
WHERE (`xf_post`.`thread_id` = 22738) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002814
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 16 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (306193, 306201))
Run Time: 0.001369
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 4 | Using index condition; Using filesort |
Params: 22738
Run Time: 0.000109
Params: 0,
Run Time: 0.000188
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=22738, 1714815175, , 0,
Run Time: 0.000172
WHERE (`xf_session_activity`.`user_id` = 25075) AND (`xf_session_activity`.`unique_key` = '25075')
Run Time: 0.000237
WHERE (`xf_thread_reply_ban`.`thread_id` = 22738) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000150
Run Time: 0.000188
bytes_sent | 12320 |
bytes_received | 324589 |
packets_sent | 124 |
packets_received | 1083 |
protocol_overhead_in | 4332 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 251788 |
packets_sent_command | 61 |
packets_received_change_user | 103 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 85 |
rows_buffered_from_client_ps | 85 |
rows_skipped_ps | 85 |
proto_binary_fetched_bit | 439 |
proto_binary_fetched_short | 282 |
proto_binary_fetched_bigint | 776 |
proto_binary_fetched_decimal | 28 |
proto_binary_fetched_json | 587 |
proto_binary_fetched_blob | 279 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 249928 |
