Run Time: 0.000708
Run Time: 0.000203
WHERE (`xf_thread`.`thread_id` = '13095')
Run Time: 0.000764
WHERE (`xf_post`.`thread_id` = 13095) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004091
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 18 | Using where; Using filesort |
Params: 13095
Run Time: 0.000110
Params: 0,
Run Time: 0.000169
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=13095, 1714836293, , 0,
Run Time: 0.000098
WHERE (`xf_session_activity`.`user_id` = 13858) AND (`xf_session_activity`.`unique_key` = '13858')
Run Time: 0.000169
WHERE (`xf_thread_reply_ban`.`thread_id` = 13095) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000191
Run Time: 0.000245
bytes_sent | 9853 |
bytes_received | 328212 |
packets_sent | 112 |
packets_received | 882 |
protocol_overhead_in | 3528 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 273474 |
packets_sent_command | 55 |
packets_received_change_user | 94 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 78 |
rows_buffered_from_client_ps | 78 |
rows_skipped_ps | 78 |
proto_binary_fetched_bit | 236 |
proto_binary_fetched_short | 325 |
proto_binary_fetched_int24 | 133 |
proto_binary_fetched_bigint | 851 |
proto_binary_fetched_json | 583 |
proto_binary_fetched_blob | 322 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 271610 |
