Run Time: 0.000725
Run Time: 0.000247
WHERE (`xf_thread`.`thread_id` = '24284')
Run Time: 0.001184
WHERE (`xf_post`.`thread_id` = 24284) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005915
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 20 | Using where; Using filesort |
Params: 24284
Run Time: 0.000105
Params: 0,
Run Time: 0.000176
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=24284, 1716207436, , 0,
Run Time: 0.000136
WHERE (`xf_session_activity`.`user_id` = 23061) AND (`xf_session_activity`.`unique_key` = '23061')
Run Time: 0.000213
Run Time: 0.000207
bytes_sent | 9344 |
bytes_received | 334956 |
packets_sent | 100 |
packets_received | 840 |
protocol_overhead_in | 3360 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 155 |
bytes_received_prepare_response_packet | 51818 |
bytes_received_change_user_packet | 282247 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 676 |
packets_received_change_user | 94 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 253 |
proto_binary_fetched_short | 359 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 621 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 280272 |
