Run Time: 0.000664
Run Time: 0.000209
WHERE (`xf_thread`.`thread_id` = '30558')
Run Time: 0.001046
WHERE (`xf_post`.`thread_id` = 30558) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003904
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 13 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (451660, 452166, 454181, 454569))
Run Time: 0.002428
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 11 | Using index condition; Using filesort |
Params: 30558
Run Time: 0.000092
Params: 0,
Run Time: 0.000156
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=30558, 1715203670, , 0,
Run Time: 0.000116
WHERE (`xf_session_activity`.`user_id` = 38510) AND (`xf_session_activity`.`unique_key` = '38510')
Run Time: 0.000166
WHERE (`xf_thread_reply_ban`.`thread_id` = 30558) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000220
Run Time: 0.000227
bytes_sent | 12359 |
bytes_received | 310776 |
packets_sent | 124 |
packets_received | 1088 |
protocol_overhead_in | 4352 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 238016 |
packets_sent_command | 61 |
packets_received_change_user | 108 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 90 |
rows_buffered_from_client_ps | 90 |
rows_skipped_ps | 90 |
proto_binary_fetched_bit | 833 |
proto_binary_fetched_short | 262 |
proto_binary_fetched_int24 | 98 |
proto_binary_fetched_bigint | 786 |
proto_binary_fetched_decimal | 35 |
proto_binary_fetched_json | 582 |
proto_binary_fetched_blob | 251 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 236147 |
