Run Time: 0.000739
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '26762')
Run Time: 0.001031
WHERE (`xf_post`.`thread_id` = 26762) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004157
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (377440))
Run Time: 0.001584
Params: 26762
Run Time: 0.000117
Params: 0,
Run Time: 0.000195
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=26762, 1715842253, , 0,
Run Time: 0.000173
WHERE (`xf_session_activity`.`user_id` = 34229) AND (`xf_session_activity`.`unique_key` = '34229')
Run Time: 0.000194
Run Time: 0.000242
bytes_sent | 11808 |
bytes_received | 355149 |
packets_sent | 112 |
packets_received | 1040 |
protocol_overhead_in | 4160 |
protocol_overhead_out | 448 |
bytes_received_prepare_response_packet | 69752 |
bytes_received_change_user_packet | 284418 |
packets_sent_command | 55 |
packets_received_prepare_response | 860 |
packets_received_change_user | 102 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 86 |
rows_buffered_from_client_ps | 86 |
rows_skipped_ps | 86 |
proto_binary_fetched_bit | 311 |
proto_binary_fetched_short | 361 |
proto_binary_fetched_bigint | 954 |
proto_binary_fetched_decimal | 24 |
proto_binary_fetched_json | 670 |
proto_binary_fetched_blob | 355 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 282324 |
