Run Time: 0.000728
Run Time: 0.000195
WHERE (`xf_thread`.`thread_id` = '36292')
Run Time: 0.000536
WHERE (`xf_post`.`thread_id` = 36292) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003560
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (554177, 554799, 555114))
Run Time: 0.001383
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 5 | Using index condition; Using filesort |
Params: 36292
Run Time: 0.000083
Params: 0,
Run Time: 0.000133
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=36292, 1716317917, , 0,
Run Time: 0.000107
WHERE (`xf_session_activity`.`user_id` = 41985) AND (`xf_session_activity`.`unique_key` = '41985')
Run Time: 0.000156
WHERE (`xf_thread_reply_ban`.`thread_id` = 36292) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000216
Run Time: 0.000169
bytes_sent | 12343 |
bytes_received | 329604 |
packets_sent | 124 |
packets_received | 1084 |
protocol_overhead_in | 4336 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 256844 |
packets_sent_command | 61 |
packets_received_change_user | 104 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 86 |
rows_buffered_from_client_ps | 86 |
rows_skipped_ps | 86 |
proto_binary_fetched_bit | 488 |
proto_binary_fetched_short | 285 |
proto_binary_fetched_bigint | 792 |
proto_binary_fetched_decimal | 29 |
proto_binary_fetched_json | 599 |
proto_binary_fetched_blob | 280 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 254951 |
