Run Time: 0.000397
Run Time: 0.000250
WHERE (`xf_thread`.`thread_id` = '37954')
Run Time: 0.000792
WHERE (`xf_post`.`thread_id` = 37954) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002273
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 14 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (588737, 588739))
Run Time: 0.001267
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 2 | Using index condition; Using filesort |
Params: 37954
Run Time: 0.000098
Params: 0,
Run Time: 0.000148
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=37954, 1715800024, , 0,
Run Time: 0.000100
WHERE (`xf_session_activity`.`user_id` = 13196) AND (`xf_session_activity`.`unique_key` = '13196')
Run Time: 0.000196
WHERE (`xf_thread_reply_ban`.`thread_id` = 37954) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000256
Run Time: 0.000216
bytes_sent | 12333 |
bytes_received | 329267 |
packets_sent | 124 |
packets_received | 1079 |
protocol_overhead_in | 4316 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 256507 |
packets_sent_command | 61 |
packets_received_change_user | 99 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 305 |
proto_binary_fetched_short | 261 |
proto_binary_fetched_int24 | 105 |
proto_binary_fetched_bigint | 705 |
proto_binary_fetched_decimal | 26 |
proto_binary_fetched_json | 557 |
proto_binary_fetched_blob | 264 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 254722 |
