Run Time: 0.000607
Run Time: 0.000215
WHERE (`xf_thread`.`thread_id` = '7484')
Run Time: 0.000754
WHERE (`xf_post`.`thread_id` = 7484) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002622
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 11 | Using where; Using filesort |
Params: 7484
Run Time: 0.000096
Params: 0, tn
Run Time: 0.000198
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: tn, XF\Pub\Controller\Thread, Index, valid, thread_id=7484, 1714716407, , 0, tn
Run Time: 0.000129
WHERE (`xf_session_activity`.`user_id` = 10495) AND (`xf_session_activity`.`unique_key` = '10495')
Run Time: 0.000167
WHERE (`xf_thread_reply_ban`.`thread_id` = 7484) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000187
Run Time: 0.000249
bytes_sent | 9839 |
bytes_received | 288049 |
packets_sent | 112 |
packets_received | 876 |
protocol_overhead_in | 3504 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 233311 |
packets_sent_command | 55 |
packets_received_change_user | 88 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 72 |
rows_buffered_from_client_ps | 72 |
rows_skipped_ps | 72 |
proto_binary_fetched_bit | 152 |
proto_binary_fetched_short | 206 |
proto_binary_fetched_int24 | 84 |
proto_binary_fetched_bigint | 544 |
proto_binary_fetched_json | 443 |
proto_binary_fetched_blob | 217 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 231850 |
