That is great. I think I'll pull out my 50mm as well and give it a try.Here's a shot that I got just a few hours ago.
My ancient (c. 1972) 50mm ƒ/1.4 NIKKOR-S mounted on my D3200; eight seconds at ƒ/1.4, ISO 200.
Not only did I get the comet, but a couple of meteors as well, in this shot.
About 19:45 PDT, at a location oddly-named El Camino de Jerry.
Did you just capture a UFO in this shot also? To the right of the comet? That's an amazing shot.Here's a shot that I got just a few hours ago.
Great shot. Did you think about removing the wires near the horizon? Photoshop has a new remove distractions feature that will automatically detect and delete cables and wires. I've tried it a couple times, and it has worked really well, with just a couple of clicks. I know some prefer to leave the scene as shot, but others prefer to clean up distractions post processing.Here's a shot that I got just a few hours ago.
I had a neighbor a couple streets over that was talking about seeing the comet in a break in the trees night before last. I waited until after dark and loaded up my camera and tripod and went to take some pictures. FYI, I'm not an astronomy photography. I took a handful of pictures at different settings. I began to have my suspicions while shooting, but was convinced once I got home and looked at the images on the computer.
Yep,
Venus
That isn't Arcturus. Arcturus is rising north of west. It is a large, bright star.Thanks, I would go out and try tonight, but we have our monthly Carolina Nature Photographer's Association meeting.
If I am reading the "map" correctly, I may have the area in my photo. Correct me if I am wrong. I looks like the star to the right of Venus and a little above is Arcturus. If not, I have my scale totally screwed up. If that is Arcturus, then the comet should be there in the photo I posted. Unfortunately, there is a lot of light pollution in this location and direction.
It has dimmed a good bit. I had a difficult time locating it with my binoculars from my front yard, which is very light polluted. I have an improperly hooded LED street light right there. We have a lot of dust in the air as well thanks to the winds. You probably need to dark adapt your eyes for a good 30 minutes to help see it.I appreciate the help. I will go out tomorrow night and see if I can spot it, weather and trees permitting.
Yeah, I had a bunch of streaks in my images too. I don't know what was causing them, but good chance it was StarLink satellites.I never saw the comet with my eyes on the 17th, but was able to locate it in the camera viewfinder of my Z5. Very light-polluted scene, but the spot was full of other astrophotographers also. We apparently all shared the same idea.
View attachment 411464View attachment 411465
First image is an exposure stack with an extra layer of foreground image that was not as badly overexposed. Second image is a single frame zoomed to 200mm. I'm guessing a StarLink is shooting by there in the middle. There was a cluster of them ruining photos.
@Afterglow967 The red linear dots are exactly what airplanes make with their marker lights as they fly through a multi-second exposure. The 2 white streaks that are prominent should be satellites, likely Starlinks. Meteors when they appear have a more "fuzzy" quality with a fade-in and fade-out at the ends if the entirety is captured.I'm pretty sure that's an aircraft. It was an eight-second exposure, so that's how far it flew across the scene in that time, with a blinking red light.
Similar to what @Clovishound captured in this post.
