Hi and thank you very much. Like I said, new to this then of course I forgot the EXIF data, but here they are;
Colour Space: sRGB
Components Configuration: 1, 2, 3, 0
Compressed Bits Per Pixel: 4
Contrast: Normal
Custom Rendered: Normal process
Date Time Digitised: 17. 2. 2025 at 21:37:32
Date Time Original: 17. 2. 2025 at 21:37:32
Digital Zoom Ratio: 1
Exif Version: 2.3
Exposure Bias Value: 0
Exposure Mode: Auto exposure
Exposure Program: Shutter priority
Exposure Time: 1/160
File Source: DSC
Flash: Off, did not fire
FlashPix Version: 1.0
FNumber: 2,8
Focal Length: 120
Focal Length In 35mm Film: 120
Gain Control: High gain up
Light Source: unknown
Max Aperture Value: 3
Metering Mode: other
Pixel X Dimension: 6 016
Pixel Y Dimension: 4 016
Saturation: Normal
Scene Capture Type: Standard
Scene Type: A directly photographed image
Sensing Method: One-chip colour area sensor
Sensitivity Type: Recommended exposure index (REI)
Sharpness: Normal
Subject Distance Range: unknown
Sub-second Time: 10
Sub-second Time Digitised: 10
Sub-second Time Original: 10
User Comment:
White Balance: Auto white balance
AFInfo: 0,304, 0,595, 0,027, 0,034, n, 0,345, 0,595, 0,027, 0,034, n, 0,387, 0,595, 0,027, 0,034, n, 0,435, 0,613, 0,031, 0,039, n, 0,484, 0,613, 0,031, 0,039, n, 0,534, 0,613, 0,031, 0,039, n, 0,586, 0,595, 0,027, 0,034, n, 0,628, 0,595, 0,027, 0,034, n, 0,669, 0,595, 0,027, 0,034, n, 0,262, 0,539, 0,027, 0,034, n, 0,304, 0,539, 0,027, 0,034, n, 0,345, 0,539, 0,027, 0,034, n, 0,387, 0,539, 0,027, 0,034, n, 0,435, 0,547, 0,031, 0,039, n, 0,484, 0,547, 0,031, 0,039, n, 0,534, 0,547, 0,031, 0,039, n, 0,586, 0,539, 0,027, 0,034, n, 0,628, 0,539, 0,027, 0,034, n, 0,669, 0,539, 0,027, 0,034, n, 0,711, 0,539, 0,027, 0,034, n, 0,262, 0,483, 0,027, 0,034, n, 0,304, 0,483, 0,027, 0,034, n, 0,345, 0,483, 0,027, 0,034, n, 0,387, 0,483, 0,027, 0,034, n, 0,435, 0,481, 0,031, 0,039, n, 0,484, 0,481, 0,031, 0,039, F, 0,534, 0,481, 0,031, 0,039, n, 0,586, 0,483, 0,027, 0,034, n, 0,628, 0,483, 0,027, 0,034, n, 0,669, 0,483, 0,027, 0,034, n, 0,711, 0,483, 0,027, 0,034, n, 0,262, 0,427, 0,027, 0,034, n, 0,304, 0,427, 0,027, 0,034, n, 0,345, 0,427, 0,027, 0,034, n, 0,387, 0,427, 0,027, 0,034, n, 0,435, 0,415, 0,031, 0,039, n, 0,484, 0,415, 0,031, 0,039, n, 0,534, 0,415, 0,031, 0,039, n, 0,586, 0,427, 0,027, 0,034, n, 0,628, 0,427, 0,027, 0,034, n, 0,669, 0,427, 0,027, 0,034, n, 0,711, 0,427, 0,027, 0,034, n, 0,304, 0,371, 0,027, 0,034, n, 0,345, 0,371, 0,027, 0,034, n, 0,387, 0,371, 0,027, 0,034, n, 0,435, 0,349, 0,031, 0,039, n, 0,484, 0,349, 0,031, 0,039, n, 0,534, 0,349, 0,031, 0,039, n, 0,586, 0,371, 0,027, 0,034, n, 0,628, 0,371, 0,027, 0,034, n, 0,669, 0,371, 0,027, 0,034, n
Flash Compensation: 0
Focus Distance: 3,981
Focus Mode: AI Servo AF
Image Number: 32 356
Image Stabilisation: Off
Lens ID: 6 001 152 606 949 629 954
Lens Info: 80, 200, 2,8, 2,8
Lens Model: AF Zoom-Nikkor 80-200mm f/2.8D ED
I never use the flash, so it was off.
