Run Time: 0.000727
Run Time: 0.000202
WHERE (`xf_thread`.`thread_id` = '17606')
Run Time: 0.000962
WHERE (`xf_post`.`thread_id` = 17606) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002487
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 8 | Using where; Using filesort |
Params: 17606
Run Time: 0.000095
Params: 0, t q
Run Time: 0.000173
Params: t q, XF\Pub\Controller\Thread, Index, valid, thread_id=17606, 1714239935, , 0, t q
Run Time: 0.000164
WHERE (`xf_session_activity`.`user_id` = 8330) AND (`xf_session_activity`.`unique_key` = '8330')
Run Time: 0.000217
WHERE (`xf_thread_reply_ban`.`thread_id` = 17606) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000228
Run Time: 0.000214
bytes_sent | 9836 |
bytes_received | 266002 |
packets_sent | 112 |
packets_received | 873 |
protocol_overhead_in | 3492 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 211223 |
packets_sent_command | 55 |
packets_received_change_user | 85 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 69 |
rows_buffered_from_client_ps | 69 |
rows_skipped_ps | 69 |
proto_binary_fetched_bit | 114 |
proto_binary_fetched_short | 156 |
proto_binary_fetched_int24 | 63 |
proto_binary_fetched_bigint | 413 |
proto_binary_fetched_json | 383 |
proto_binary_fetched_blob | 172 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 209963 |
