Run Time: 0.000478
Run Time: 0.000200
WHERE (`xf_thread`.`thread_id` = '10512')
Run Time: 0.000833
WHERE (`xf_post`.`thread_id` = 10512) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002174
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (106913))
Run Time: 0.001067
Params: 10512
Run Time: 0.000094
Params: 0, 0
Run Time: 0.000148
Params: 0, XF\Pub\Controller\Thread, Index, valid, thread_id=10512, 1714282147, , 0, 0
Run Time: 0.000129
WHERE (`xf_session_activity`.`user_id` = 12256) AND (`xf_session_activity`.`unique_key` = '12256')
Run Time: 0.000167
WHERE (`xf_thread_reply_ban`.`thread_id` = 10512) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000206
Run Time: 0.000182
bytes_sent | 12304 |
bytes_received | 295973 |
packets_sent | 124 |
packets_received | 1075 |
protocol_overhead_in | 4300 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 223172 |
packets_sent_command | 61 |
packets_received_change_user | 95 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 77 |
rows_buffered_from_client_ps | 77 |
rows_skipped_ps | 77 |
proto_binary_fetched_bit | 197 |
proto_binary_fetched_short | 192 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 515 |
proto_binary_fetched_json | 473 |
proto_binary_fetched_blob | 203 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 221676 |
