Run Time: 0.000736
Run Time: 0.000202
WHERE (`xf_thread`.`thread_id` = '28532')
Run Time: 0.001080
WHERE (`xf_post`.`thread_id` = 28532) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002367
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 8 | Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (411261))
Run Time: 0.001426
Params: 28532
Run Time: 0.000087
Params: 0, v~
Run Time: 0.000143
Params: v~, XF\Pub\Controller\Thread, Index, valid, thread_id=28532, 1716034412, , 0, v~
Run Time: 0.000120
WHERE (`xf_session_activity`.`user_id` = 36632) AND (`xf_session_activity`.`unique_key` = '36632')
Run Time: 0.000164
WHERE (`xf_thread_reply_ban`.`thread_id` = 28532) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000226
Run Time: 0.000206
bytes_sent | 12304 |
bytes_received | 289041 |
packets_sent | 124 |
packets_received | 1073 |
protocol_overhead_in | 4292 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 216240 |
packets_sent_command | 61 |
packets_received_change_user | 93 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 75 |
rows_buffered_from_client_ps | 75 |
rows_skipped_ps | 75 |
proto_binary_fetched_bit | 175 |
proto_binary_fetched_short | 157 |
proto_binary_fetched_int24 | 63 |
proto_binary_fetched_bigint | 426 |
proto_binary_fetched_json | 433 |
proto_binary_fetched_blob | 173 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 214848 |
