Run Time: 0.000360
Run Time: 0.000189
WHERE (`xf_thread`.`thread_id` = '26688')
Run Time: 0.000877
WHERE (`xf_post`.`thread_id` = 26688) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.003210
Params: 26688
Run Time: 0.000103
Params: 0,
Run Time: 0.000133
WHERE (`xf_session_activity`.`user_id` = 29753) AND (`xf_session_activity`.`unique_key` = '29753')
Run Time: 0.000173
Run Time: 0.000240
bytes_sent | 8942 |
bytes_received | 329755 |
packets_sent | 94 |
packets_received | 828 |
protocol_overhead_in | 3312 |
protocol_overhead_out | 376 |
bytes_received_rset_header_packet | 297 |
bytes_received_rset_row_packet | 103 |
bytes_received_prepare_response_packet | 51575 |
bytes_received_change_user_packet | 277366 |
packets_sent_command | 46 |
packets_received_rset_header | 33 |
packets_received_rset_row | 17 |
packets_received_prepare_response | 667 |
packets_received_change_user | 94 |
result_set_queries | 14 |
non_result_set_queries | 3 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 14 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 253 |
proto_binary_fetched_short | 359 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 620 |
com_stmt_prepare | 15 |
com_stmt_execute | 15 |
com_stmt_close | 14 |
bytes_received_real_data_ps | 275387 |
