Run Time: 0.000510
Run Time: 0.000254
WHERE (`xf_thread`.`thread_id` = '44788')
Run Time: 0.000796
WHERE (`xf_post`.`thread_id` = 44788) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001486
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 4 | Using where; Using filesort |
Params: 44788
Run Time: 0.000102
Params: 0, D
Run Time: 0.000166
Params: D, XF\Pub\Controller\Thread, Index, valid, thread_id=44788, 1714212663, , 0, D
Run Time: 0.000178
WHERE (`xf_session_activity`.`user_id` = 26896) AND (`xf_session_activity`.`unique_key` = '26896')
Run Time: 0.000217
WHERE (`xf_thread_reply_ban`.`thread_id` = 44788) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000222
Run Time: 0.000217
bytes_sent | 9840 |
bytes_received | 245053 |
packets_sent | 112 |
packets_received | 869 |
protocol_overhead_in | 3476 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 190274 |
packets_sent_command | 55 |
packets_received_change_user | 81 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 65 |
rows_buffered_from_client_ps | 65 |
rows_skipped_ps | 65 |
proto_binary_fetched_bit | 67 |
proto_binary_fetched_short | 88 |
proto_binary_fetched_int24 | 35 |
proto_binary_fetched_bigint | 236 |
proto_binary_fetched_json | 303 |
proto_binary_fetched_blob | 112 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 189240 |
