Run Time: 0.000508
Run Time: 0.000211
WHERE (`xf_thread`.`thread_id` = '18071')
Run Time: 0.001003
WHERE (`xf_post`.`thread_id` = 18071) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004805
Params: 18071
Run Time: 0.000083
Params: 0, :Mb
Run Time: 0.000121
WHERE (`xf_session_activity`.`user_id` = 17976) AND (`xf_session_activity`.`unique_key` = '17976')
Run Time: 0.000199
WHERE (`xf_thread_reply_ban`.`thread_id` = 18071) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000269
Run Time: 0.000233
bytes_sent | 9438 |
bytes_received | 330016 |
packets_sent | 106 |
packets_received | 873 |
protocol_overhead_in | 3492 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 275557 |
packets_sent_command | 52 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_skipped_ps | 81 |
proto_binary_fetched_bit | 258 |
proto_binary_fetched_short | 362 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 273580 |
