Run Time: 0.000466
Run Time: 0.000242
WHERE (`xf_thread`.`thread_id` = '19510')
Run Time: 0.000852
WHERE (`xf_post`.`thread_id` = 19510) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.005240
SIMPLE | xf_post | range | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_position | 8 | | 21 | Using index condition; Using where; Using filesort |
WHERE (`xf_attachment`.`content_type` = 'post' AND `xf_attachment`.`content_id` IN (244557, 244707))
Run Time: 0.001518
SIMPLE | xf_attachment | range | content_type_id_date,content_type | content_type_id_date | 31 | | 21 | Using index condition; Using filesort |
Params: 19510
Run Time: 0.000089
Params: 0,
Run Time: 0.000126
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=19510, 1714681405, , 0,
Run Time: 0.000091
WHERE (`xf_session_activity`.`user_id` = 9240) AND (`xf_session_activity`.`unique_key` = '9240')
Run Time: 0.000163
WHERE (`xf_thread_reply_ban`.`thread_id` = 19510) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000191
Run Time: 0.000211
bytes_sent | 12329 |
bytes_received | 367779 |
packets_sent | 124 |
packets_received | 1104 |
protocol_overhead_in | 4416 |
protocol_overhead_out | 496 |
bytes_received_change_user_packet | 295019 |
packets_sent_command | 61 |
packets_received_change_user | 124 |
result_set_queries | 18 |
ps_buffered_sets | 18 |
rows_fetched_from_server_ps | 106 |
rows_buffered_from_client_ps | 106 |
rows_skipped_ps | 106 |
proto_binary_fetched_bit | 1520 |
proto_binary_fetched_short | 401 |
proto_binary_fetched_bigint | 1233 |
proto_binary_fetched_decimal | 45 |
proto_binary_fetched_json | 771 |
proto_binary_fetched_blob | 354 |
com_stmt_prepare | 20 |
com_stmt_execute | 20 |
com_stmt_close | 19 |
bytes_received_real_data_ps | 292494 |
