Run Time: 0.000435
Run Time: 0.000237
WHERE (`xf_thread`.`thread_id` = '33895')
Run Time: 0.000639
WHERE (`xf_post`.`thread_id` = 33895) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002362
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 8 | Using where; Using filesort |
Params: 33895
Run Time: 0.000129
Params: 0, ڨ
Run Time: 0.000190
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: ڨ, XF\Pub\Controller\Thread, Index, valid, thread_id=33895, 1714932539, , 0, ڨ
Run Time: 0.000121
WHERE (`xf_session_activity`.`user_id` = 40739) AND (`xf_session_activity`.`unique_key` = '40739')
Run Time: 0.000188
WHERE (`xf_thread_reply_ban`.`thread_id` = 33895) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000198
Run Time: 0.000203
bytes_sent | 9847 |
bytes_received | 270269 |
packets_sent | 112 |
packets_received | 873 |
protocol_overhead_in | 3492 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 215531 |
packets_sent_command | 55 |
packets_received_change_user | 85 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 69 |
rows_buffered_from_client_ps | 69 |
rows_skipped_ps | 69 |
proto_binary_fetched_bit | 114 |
proto_binary_fetched_short | 157 |
proto_binary_fetched_int24 | 63 |
proto_binary_fetched_bigint | 412 |
proto_binary_fetched_json | 383 |
proto_binary_fetched_blob | 172 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 214251 |
