Run Time: 0.000597
Run Time: 0.000213
WHERE (`xf_thread`.`thread_id` = '32411')
Run Time: 0.000835
WHERE (`xf_post`.`thread_id` = 32411) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.004465
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 19 | Using where; Using filesort |
Params: 32411
Run Time: 0.000095
Params: 0, 8r
Run Time: 0.000162
Params: 8r, XF\Pub\Controller\Thread, Index, valid, thread_id=32411, 1714290770, , 0, 8r
Run Time: 0.000134
WHERE (`xf_session_activity`.`user_id` = 40512) AND (`xf_session_activity`.`unique_key` = '40512')
Run Time: 0.000195
WHERE (`xf_thread_reply_ban`.`thread_id` = 32411) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000232
Run Time: 0.000232
bytes_sent | 9840 |
bytes_received | 325404 |
packets_sent | 112 |
packets_received | 884 |
protocol_overhead_in | 3536 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 270625 |
packets_sent_command | 55 |
packets_received_change_user | 96 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_skipped_ps | 80 |
proto_binary_fetched_bit | 248 |
proto_binary_fetched_short | 342 |
proto_binary_fetched_int24 | 140 |
proto_binary_fetched_bigint | 896 |
proto_binary_fetched_json | 603 |
proto_binary_fetched_blob | 337 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 268708 |
