Run Time: 0.000765
Run Time: 0.000188
WHERE (`xf_thread`.`thread_id` = '7519')
Run Time: 0.000801
WHERE (`xf_post`.`thread_id` = 7519) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002012
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 3 | Using where; Using filesort |
Params: 7519
Run Time: 0.000090
Params: 0, t(K
Run Time: 0.000162
Params: t(K, XF\Pub\Controller\Thread, Index, valid, thread_id=7519, 1715712721, , 0, t(K
Run Time: 0.000148
WHERE (`xf_session_activity`.`user_id` = 6548) AND (`xf_session_activity`.`unique_key` = '6548')
Run Time: 0.000162
WHERE (`xf_thread_reply_ban`.`thread_id` = 7519) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000175
Run Time: 0.000228
bytes_sent | 9828 |
bytes_received | 240618 |
packets_sent | 112 |
packets_received | 868 |
protocol_overhead_in | 3472 |
protocol_overhead_out | 448 |
bytes_received_change_user_packet | 185839 |
packets_sent_command | 55 |
packets_received_change_user | 80 |
result_set_queries | 16 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 64 |
rows_buffered_from_client_ps | 64 |
rows_skipped_ps | 64 |
proto_binary_fetched_bit | 56 |
proto_binary_fetched_short | 70 |
proto_binary_fetched_int24 | 28 |
proto_binary_fetched_bigint | 192 |
proto_binary_fetched_json | 283 |
proto_binary_fetched_blob | 97 |
com_stmt_prepare | 18 |
com_stmt_execute | 18 |
com_stmt_close | 17 |
bytes_received_real_data_ps | 184870 |
