Run Time: 0.000501
Run Time: 0.000178
WHERE (`xf_thread`.`thread_id` = '644')
Run Time: 0.000847
WHERE (`xf_post`.`thread_id` = 644) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.001333
Params: 644
Run Time: 0.000101
Params: 0, w~P
Run Time: 0.000174
WHERE (`xf_session_activity`.`user_id` = 257) AND (`xf_session_activity`.`unique_key` = '257')
Run Time: 0.000194
WHERE (`xf_thread_reply_ban`.`thread_id` = 644) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000228
Run Time: 0.000261
bytes_sent | 9416 |
bytes_received | 248228 |
packets_sent | 106 |
packets_received | 858 |
protocol_overhead_in | 3432 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 193769 |
packets_sent_command | 52 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_skipped_ps | 66 |
proto_binary_fetched_bit | 80 |
proto_binary_fetched_short | 104 |
proto_binary_fetched_bigint | 280 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 192684 |
