Run Time: 0.000690
Run Time: 0.000212
WHERE (`xf_thread`.`thread_id` = '39355')
Run Time: 0.000786
WHERE (`xf_post`.`thread_id` = 39355) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002113
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 3 | Using where; Using filesort |
Params: 39355
Run Time: 0.000107
Params: 0,
Run Time: 0.000173
ip,
controller_name,
controller_action,
view_state,
params,
view_date,
robot_key,
user_id,
unique_key
Params: , XF\Pub\Controller\Thread, Index, valid, thread_id=39355, 1715351736, , 0,
Run Time: 0.000111
WHERE (`xf_thread_reply_ban`.`thread_id` = 39355) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000225
Run Time: 0.000203
bytes_sent | 9361 |
bytes_received | 238985 |
packets_sent | 100 |
packets_received | 818 |
protocol_overhead_in | 3272 |
protocol_overhead_out | 400 |
bytes_received_rset_header_packet | 306 |
bytes_received_rset_row_packet | 114 |
bytes_received_prepare_response_packet | 51458 |
bytes_received_change_user_packet | 186677 |
packets_sent_command | 49 |
packets_received_rset_header | 34 |
packets_received_rset_row | 18 |
packets_received_prepare_response | 672 |
packets_received_change_user | 76 |
result_set_queries | 14 |
ps_buffered_sets | 14 |
ps_prepared_once_executed | 15 |
rows_fetched_from_server_ps | 62 |
rows_buffered_from_client_ps | 62 |
rows_skipped_ps | 62 |
proto_binary_fetched_bit | 38 |
proto_binary_fetched_short | 72 |
proto_binary_fetched_int24 | 28 |
proto_binary_fetched_bigint | 193 |
proto_binary_fetched_decimal | 18 |
proto_binary_fetched_json | 288 |
proto_binary_fetched_blob | 97 |
com_stmt_prepare | 16 |
com_stmt_execute | 16 |
com_stmt_close | 15 |
bytes_received_real_data_ps | 185720 |
