Run Time: 0.000698
Run Time: 0.000208
WHERE (`xf_thread`.`thread_id` = '24311')
Run Time: 0.000802
WHERE (`xf_post`.`thread_id` = 24311) AND ((`xf_post`.`message_state` IN ('visible'))) AND (`xf_post`.`position` >= 0) AND (`xf_post`.`position` < 20)
Run Time: 0.002955
SIMPLE | xf_post | ref | thread_id_post_date,thread_id_position,thread_id_score_date | thread_id_post_date | 4 | const | 10 | Using where; Using filesort |
Params: 24311
Run Time: 0.000101
Params: 0, K
Run Time: 0.000154
WHERE (`xf_session_activity`.`user_id` = 15805) AND (`xf_session_activity`.`unique_key` = '15805')
Run Time: 0.000172
WHERE (`xf_thread_reply_ban`.`thread_id` = 24311) AND (`xf_thread_reply_ban`.`user_id` = 4294967295)
Run Time: 0.000198
Run Time: 0.000173
bytes_sent | 9438 |
bytes_received | 275944 |
packets_sent | 106 |
packets_received | 863 |
protocol_overhead_in | 3452 |
protocol_overhead_out | 424 |
bytes_received_change_user_packet | 221485 |
packets_sent_command | 52 |
packets_received_change_user | 87 |
result_set_queries | 16 |
non_result_set_queries | 3 |
ps_buffered_sets | 16 |
rows_fetched_from_server_ps | 71 |
rows_buffered_from_client_ps | 71 |
rows_skipped_ps | 71 |
proto_binary_fetched_bit | 139 |
proto_binary_fetched_short | 190 |
proto_binary_fetched_int24 | 77 |
proto_binary_fetched_bigint | 500 |
proto_binary_fetched_json | 423 |
proto_binary_fetched_blob | 202 |
com_stmt_prepare | 17 |
com_stmt_execute | 17 |
com_stmt_close | 16 |
bytes_received_real_data_ps | 220105 |
